pappaoneExplorerJun 18, 2014PVC pipe has crackNoticed that PVC line between grey tank and drain valve has hair line crack in it. Is the a way to fix it without having to replace the pipe? Maybe with JD Weld for PVC & Plastic?? Thank youShow More
pappaoneExplorerJun 18, 2014Thank you Scott, I didn't even think about using the cement to fill in the crack. It is a short crack so will get some ABS cement and give it a try.
Related Contentmaking a pvc sewer pipePVC Vent Pipe Mod QuestionPVC roof failurePVC Pipe Solvent/Cement, How do you Prolong in storage ?Do holding tank weathervanes glue to standard PVC pipe?
