mkguitar
Nov 08, 2015Explorer
I use about 4 tablespoons of "di-chlor" pool shock in mine to a full tank.
mix it up and drive around- let it sit overnight and drain...you can also run through your tubing to help clean it out
I pour the pool shock into a thick walled cleaned and dried plastic water bottle- Perrier at the moment- and the shock is protected from spilling or moisture- the neck makes for an easy pour. easier than carrying around bleach and a higher concentration ( some household beaches are about 7%)
this can also be used to treat "suspect water" while camping- but just 1 or 2 tablespoons per tank.
a bag of shock will cost a couple of bucks and last a few seasons.
we have a pool so I have the chemicals anyway
more:
http://rvbasics.com/techtips/sanitizing-your-rv-fresh-water-system.html
now for the black and grey tanks....I am considering a colony of aquarium snails in there...see if they eat all the stuff !
Mike
more:
Mike
