majordad's avatar
majordad
qd7500 generator won't start
my 2001 Fleetwood Discovery has a Onan QD7500 generator which will not start. My mechanic was able to jump it at the starter and then it started and stopped normally. But since we returned from a trip and it is plugged into shore power, I cannot get it to start, any ideas??
  • Well considering all the experts I talked with, no one ever mentioned that with a diesel generator, you have to hold the start button for 20-30 seconds to heat glow plugs, etc before it will start.
    As for me, lesson learned. Thank you to all who tried to help
  • coach is currently in shop and they are looking at the solenoid, Thanks
  • KW4G wrote:
    If your mechanic was able to start the generator by jumping it at the starter, I would suspect a bad solenoid.
    X2 if the mechanic did not use a external battery source.
  • If your mechanic was able to start the generator by jumping it at the starter, I would suspect a bad solenoid.
