ron_dittmer
Jun 24, 2019Explorer III
Towing anything including a boat that weighs 3500 pounds should not be an issue with any DRW motor home including an E350 Ford and 3500 Chevy, as long as the tongue weight is under 500 pounds. For at least 12 years now, motor home hitches have a rating of 5000 pounds, and most recently increased to 7500 pounds.
One thing to consider is the approach angle launching a boat into the water. You might consider a front tow bar with a ball hitch so you can launch the boat with the front of the motor home facing the water. Launching rearward as is normal, the rear extended overhang of the RV could be a problem on certain boat ramps, causing the boat trailer hitch to go too high in the air before the RV starts down the ramp.
