Chum_lee
Jun 28, 2019Explorer
Gjac wrote:Chum lee wrote:What 24 ft Class C would meet these requirements?ron.dittmer wrote:
One thing to consider is the approach angle launching a boat into the water. You might consider a front tow bar with a ball hitch so you can launch the boat with the front of the motor home facing the water. Launching rearward as is normal, the rear extended overhang of the RV could be a problem on certain boat ramps, causing the boat trailer hitch to go too high in the air before the RV starts down the ramp.
IMO, this is a very good point, not just for towing but for driving in general. Keeping the rear overhang (behind the rear wheels) to a minimum is important to minimize the chances of grounding the trailer hitch which happens when you traverse sharp grade changes. In a Class C, having higher ground clearance, a longer wheelbase, and less rear overhang will minimize the chances of grounding which is surprisingly easy to do. (and it's a little embarrassing if you get stuck)
Chum lee
I don't have a specific example for the OP in this case. My point was that the OP should consider the chassis dimensions, carefully, before deciding on a specific model. For example: My Class A (Ford F53) has a 178" wheelbase, it's 30'-9" long overall and has about an 11' overhang behind the rear wheels. If I used it for towing a boat, IMO, a better choice would have been a 208" wheelbase, 30'-9" long with a shorter rear overhang (+-8.5 feet in my case) As Phil mentions, (under some conditions) the potential to ground the center would be increased, but the safety margin for grounding the rear (in a towing situation) would be improved. Having larger wheels (22.5" instead of 19.5" in my case) would also help improve the ground clearance in a towing situation. I could opt for larger wheels in my Class A, but, I'm not sure a larger wheel option is available in a Class C.
My point being that if you don't understand/think about your limitations/options in advance, making the best buying decision tends to be reduced to nothing more than a lucky guess. It doesn't have to be.
Chum lee
