fbconsults1
Jan 02, 2016Explorer
I have a 2011 Georgetown 378TS, a Class A gas MH on a Ford F53 Chassis, with 22.5 tires. I encountered the wandering problem when I first got it, and fixed it with the following:
1. Front end alignment, toe in set to max specs
2. Inflate tires to 95 PSI
3. Do the Cheap Handling Fix, which is to move the sway bar bolts to the rear hole from the front. Google this for more info.
This should work on all F53 Chassis motorhomes.
Happy Trails, Forrest
38,776 PostsLatest Activity: May 15, 2026
