dougrainer
Jun 09, 2015Nomad
Newmar Dutch Star the front dash 12 volt plugs are usually connected to the COACH battery system and not the Chassis battery system. See if the 11.1 matches the coach battery voltage. A Defective ATC fuse can cause that type of low voltage when the main supply is indeed over 12.8 volts. If you plug in a 12 volt appliance, it will not work but the voltmeter will read the bleed thru the defective or partially blown fuse. Doug
38,769 PostsLatest Activity: Apr 03, 2026
