dougrainer
Jun 09, 2015Nomad
lanerd wrote:dougrainer wrote:
=or partially blown fuse. Doug
Really? A "partially" blown fuse??? With all due respect, how is that even possible?
Snomas...try attaching a separate piece of wire to the ground side of the 12v socket and ground it to the metal frame somewhere. Bet you will read the same or a fraction less that what the batteries read.
Good luck
Ron
Don't know "how" it happens. But I have seen it numerous times. The tungsten in the fuse "melts" but there is a charred sliver left and is enough to cause a voltmeter to read less than the supply voltage. When I get that reading, I then check the voltage on both sides of the fuse. I find that on the HOT side of the fuse I get the normal 12.8 to 13.6 volts and then that less than 12 on the "cold" side of the fuse. Doug
38,769 PostsLatest Activity: Apr 03, 2026
