Tinstar's avatar
Tinstar
Question about slide seal
On my slides I have a wiper seal that I have a question about. The seal long lip is sometimes outside the opening like in the below picture. I think that is the way it is supposed to be when the slide is extended. Sometimes on the bedroom slide, the lip stays inside the opening all the way around the slide. I guess the best way to describe it is 'inverted'. Is it alright for it to be inverted or do I need to make sure the lip is outside?
  • Someone suggested the "loop" half of a strip of Velcro tape instead of step tread tape. It's less abrasive and does the same job.
  • Those are 'wipers' not seals
    They wipe sides/top of moisture and debris
    They function as designed regardless if they 'flip' or don't
    Not a concern
  • It looks like it is right. The seal should "flip" whenever the slie is extended or retracted, but as they get older and the seal gets stiffer, sometimes they do and sometimes they don't. Some people recommend putting a strip of step tread material on the side of the slide to help flip the seal. I usually just don't worry about it, but if we are going to be in the same place for a while, I will usually go around and flip ours if necessary.
  • The wipe seal is not required to flip completely out or in. That is not the true seal when extended or retracted.
    If it concerns you can install sandpaper type tape on the sidewall to rub the seal completly in and out. Doug
