treeguy100
Jan 15, 2014Explorer
Hey Mich,
No, the Suburban thermostat does not have any other switches that I can see on the bottom or inside of the cover either. On the top it has the slide switch to adjust the temp. On the degree settings on the front (that little window where you line up the slide switch with desired temp) it says the following: OFF 50 60 70 80 90. To me, that means far left is off. I took the cover off and checked, and there aren't any other switches than the one on top. Thanks for the suggestion though!
Scott
Scott
