Bandaid's avatar
Bandaid
Explorer II
May 30, 2022
Sunseeker classic questions
I have a 2021 Sunseeker and I have an air leak in the passengers side airbag system. I have it narrowed down to the fitting on the top of the airbag, however, getting to the location of the fitting appears to be difficult to say the least! Has anyone tried resealing this fitting and what did you have to remove to gain access to the top of the bag?
My unit also came equipped with the Bilstein shocks. While under the unit looking for a way to access the airbag fitting, I noticed the top of the shock goes through a metal sheet. How, or where do you gain access to the top of the shock should it need to be removed and replaced?
Ratracer.
  • If i remember correctly, you have to remove the bag being there is little clearance on top.
    An interesting video shows a spring swap eliminating the need for AB’s. I did this on one of my trucks and it worked real nice. No more AB’s for me.
    This youtube shows the springs for a class C at the 12+ min mark.
    https://youtu.be/1-2BbIYorgI
  • Having spent time repairing various models of RV's from tent trailers to Provost I can tell you that there is no set formula to answer your questions . Often I have to just stare at something
    and consider all possibilities. The air bag may need to come off to gain access to the top. Interesting the shocks go into the metal shielding. Doubtful there is any access from inside.
    The sheet metal may have to be removed. Post some photos of both and see what we can come up with.
