treeguy100
Jan 15, 2014Explorer
Question about Sunseeker 2450 furnace
Hi everyone - we are new to both RV’ing and RV.net, but I have a question that I’m hopeful can be answered by one of you seasoned vets around here! We recently purchased a bank-owned 2004 Sunseeker 2450. As it was bank-owned we got a sweet deal on it, but unfortunately there wasn’t any pre-delivery walkthrough or training to get us up to speed on how everything works. Subsequently I’ve been spending a lot of time on Youtube catching up on how most of the basics work. One problem we are having, though, is that I can’t seem to get the darned furnace to start up. Here are the specifics of what I have done to try and get it started so far:
1 - Topped off the propane tank and opened the valve for use.
2 - I purged the LPG lines of air by starting all of the burners on the stove and letting them burn for a couple minutes.
3 - I checked the LPG Gas Detector to make sure it was on. It appears to be a model that does not have an on/off switch, so it appears to be on all the time. It has a mute button but that’s it. The green light is on (constant green light, not blinking) showing that it is “Operating”.
4 - The battery disconnect is ON.
5 - I moved the Suburban thermostat from “Off” to about 80 degrees, well above the internal temp of 60 degrees.
6 - Waited for a couple minutes and nothing happened at this point. No clicking from the electric igniter at all. On the RV monitor (that thingy that shows the levels of each water tank, house batteries, etc) there is a rocker switch that says “HTR” on it. Assuming this is for the furnace, I clicked it ON and it lights up red. Waited for a couple more minutes and nothing happened.
7 - I used a multi-meter to check all of the fuses to the house and they all appear to be working correctly. At least they all show a charge going through when I touch the leads to both sides of each fuse.
8 - One odd thing I noticed is that when I slide the thermostat from off to on, there is a very very quiet whistle or beep noise (it is a constant beep noise - like beeeeeeeeeeeep, not beep-beep-beep) that I can hear coming from behind the air return near the floor. When I slide the thermostat back to off, the tiny noise goes away.
At this point I am lost on what possibly to do next, so clearly I am missing some step that would help get the furnace to fire up and heat the RV. Do the switches next to the battery disconnect have anything to do with it? The right switch appears to operate the electric step, but the left one when flipped lights up red but nothing happens. I thought it might operate the light outside the entry door, but since nothing happened I figured the light must be burned out. Does the HTR switch even have anything to do with the furnace at all? Any help or suggestions you pro’s can provide would be greatly appreciated! I’d hate to take it in to the shop just for the techs to tell me something basic, like I need to have the key in the ignition or something simple like that.
Thanks!
Scott
Thanks!
Scott
