cbigham
Oct 04, 2021Explorer III
phillyg wrote:
Nothing to be concerned about IMHO, but you should invest in an infrared temp gauge. My rears will always show higher temps when pulling my fiver.
Your number, ratio is about what I calculated. I'm still under the 9600 lbs rear axle weight. That's the factor, tho this is the most weight I've had on the rear axle which likely is.
