4x4van
Oct 05, 2021Explorer III
2 quick thoughts; based on your weight ticket, you have only 660 lbs available on the rear axle; if you added the bike after that ticket, then your axle IS overloaded. Also, is that 80-82 psi that you referred to the cold pressure (before driving), or is that the pressure after driving and when the tires were hot?
