wolfe10 wrote:
If you have the correct dual rear wheel spacing/off-set you really should have room to go between the tires. Exception would be at the 6:00 position where the tire bulge will narrow the gap. At 3:00 or 9:00 (which ever give you easier access in terms of coach body) you should be good to go.
But, if you do get DW to do it, please post the cost, as we want to make sure future DW's do not overcharge for this.
I don't think I'll have to worry about DW doing it. I do have factory wheels and tires so there is probably enough room.
