Gundog
Aug 26, 2018Explorer II
tropical36 wrote:Gundog wrote:
I went to see it this morning what a journey this thing was in the middle of nowhere at the end of a dirt road. It was in really nice shape but I just don't think it will work for me. It was a really short wheel base rig and was only rated to tow 4000# I need to tow an 8500# boat part of the time. It is a shame because it was really nice but they need to move it somewhere else to get people to look at it I almost turned back several times. My search continues I think I am going to start looking at longer rigs 34' to 36' maybe even up to 38'. I am tired of looking for now I may wait until next spring no need to get a rig just in time to winterize it.
You're right about the longer wheelbase and another factor that contributes to towing weight.
If you'll just bite the bullet and go for a good 40ft DP and I did say a good one and not with a 2500 series tranny that will pull next to nothing. In fact, weak transmissions are the real sore spot and usually the weak link, when it comes to pulling power.
There's other factors to consider and worth checking out, as well.
EXP.... I can pull 15k and the specs. do match, but with the GVWR, as it is and even though a ton to the good when fully loaded, it's all to the front. Meaning that the rear axle is at max or a little over and not a biggie, unless I add to the hitch weight, which is rated at 1500lbs. Pretty stupid with these ratings they advertise, when they know better and one shouldn't have to be doing math, just for picking out a coach, that will suit their needs. Since we pull 4 down, it's no biggie and the Jeep is not a factor at all, but if we should choose to pull a trailer of any sort, then possibly a weight distribution hitch, would be in order.
I really don't want to go 40' 35' or 36' could work the problem I am having is I am not looking for new and finding the right one that has the towing capacity is difficult because I really don't know what models and brands will have the larger towing capacity.
38,769 PostsLatest Activity: Apr 03, 2026
