willald
Nov 26, 2015Explorer II
..I use a ReadyBrake Elite tow bar with the integrated braking system as well. Have used it on two different toads, it has worked great on both of them.
Yes, the way NSA has you install it, wiring the dashboard light to work of the ReadyBrake actuator....Well, is not very useful. You really, really need it to tell you when the toad brakes are engaging, not when the readybrake actuator moves.
Sooo, I too, wired the dash light to the toad's brake light. Is very, very handy, to know precisely when you toad brakes engage and when they disengage. I would not want to tow a vehicle without such. You really need an indicator like this, regardless what type of brake system you are using.
NSA used to instruct you to wire up their dash light that way, to the toad brake lights. However, they changed that to the way it is now some time ago. As I understand it, it was changed because so many toads require you to pull fuses or disconnect the battery, which in many cases would make it difficult to wire the dash indicator to work off of toad brake lights.
