Nevadastars
May 28, 2015Explorer
Actually guys, like I said above, I just spent nearly $700 having the front end checked out by the most reputable RV alignment shop within 100 miles. They installed the caster shims, to give it over 5 degrees of positive caster on both sides. It is better, but still has the play in the wheel. They said all front end parts are fine. Again, this rig only has 12k on it.
I called the shop that did the work (70 miles away) and told them about the play, and they said I could put a Safe-T-Plus on it. But I was hoping someone here could tell me if it actually helps.
38,768 PostsLatest Activity: Nov 21, 2015
