10forty2
Sep 21, 2015Explorer
In DC circuitry (on the supply side at least), typically the positive is indicated by a red wire and the negative is indicated by a black wire. If it's a grounded system then the ground wire is usually green or bare. Not sure what the white and yellow indicate on the detector.
In AC circuitry, white is neutral, black is hot, and green or bare is ground. A red wire in AC circuitry is usually a switched hot lead.
