enblethen
Feb 06, 2014Nomad
There is a check valve inside the coach where the hose attaches.
Disconnect hose, look inside rig's connection point. There should be a small nose sticking out. This is the check valve plunger. Push on it gently. it should be spring loaded and return when you release it.
38,766 PostsLatest Activity: Jan 10, 2026
