OhhWell
Feb 07, 2014Explorer
Bumpyroad wrote:enblethen wrote:
There is a check valve inside the coach where the hose attaches.
Disconnect hose, look inside rig's connection point. There should be a small nose sticking out. This is the check valve plunger. Push on it gently. it should be spring loaded and return when you release it.
be sure to have your face right in front of the opening and close when you push that plunger. :)
bumpy
Very good advice! It is usually hard to see into the inlet enough to see the end of the plunger clearing the flange. you have to really get up CLOSE! :B
38,766 PostsLatest Activity: Jan 10, 2026
