bobojay5
Mar 06, 2014Explorer
For the OP, in case you didn't know it, all Sprinters of any of the 3 brands, Dodge, MB or Freightliner are the same vehicle, all manufactured by Mercedes. Only differences will be grilles, steering wheel horn covers and of course the badging.
We've owned 2 Sprinter RV's now, a class C & a B, 2009 & '13. We have had no issues at all in the mountains with pulling the grade. You learn to manually shift to 3rd gear and cruise up at 40 to 45 mph with the ability to pass, the Ford especially, class C's you come upon with no effort or strain. We've never pulled a toad with either RV not seeing the need to as we usually don't sit in any one spot for more than a day or 2, and both of the Sprinters would fit anywhere we ever took them.
Recommendation is if you want a Sprinter class B, to look for a 2005 or '06 chassis, or a 2008 on up chassis class B. The '05 & '06 would be on the T1N Sprinter, which is the original one that was sold here, least complicated with a bulletproof and non-troublesome 5cyl engine. Only issue with the T1N is rust & the turbo resonator which is an easy fix.
The NCV3 Sprinter is the 2007 on up model. Recommend staying away from the 2007 chassis, as it's had it's share of service bulletins and recalls. The 2008 on up ones have issues with emissions equipment which gets more complicated as the years go on. Their biggest issue is the EGR valve which gets clogged up from too much idling and just plain letting the engine lug around. Also the Diesel Particulate Filter which clogs up faster the more you idle and drive at lower RPM's. The V6 engine itself is bulletproof and a model of smoothness.
The biggest Sprinter issue though is lack of service facilities. They are sometimes hundreds of miles apart. And just because the dealer says Mercedes or Freightliner, doesn't mean they service Sprinters. For instance, we live in a metro area with a population of 1 million, and only have 2 Sprinter servicing dealers, one MB and one Freightliner. Neither one of these currently can do front end alignments on Sprinters unless things have changed in the last 90 days.
Hope this helps you
Hope this helps you
38,782 PostsLatest Activity: Aug 11, 2021
