Golden_HVAC
Aug 15, 2014Explorer
What you can check to make sure that this is the problem is disconnect the wire going to the starter, then check the ignition system by turning it on and off, see if you get 12 volts each time. By hooking up something with a load, such as a 4 amp fog light, you will quickly determine if it is working or not.
Chances are that the starter is the problem. You can test it too. Use a momentary on-off switch, they are sold at auto parts stores with alligator clips already on them. Test the starter by pressing the button, each time the starter should spin the motor.
What else can go wrong? Fuel pressure relay? Fuel filter clogged? Does it work well while climbing a mountain?
I really like the layout of my Bounder. I actually have a 97 that was built and delivered to me on November 8, 1996. They actually built the RV a week earlier, but had no couches, and I had to wait another week for the RV to arrive from nearby Riverside Factory. It had 80 miles on it. I also got to tour the factory in the summer of 96. It was interesting to see how the walls where built, and installed on the frame, and furniture installed. They pump water into the tanks, and make sure it does not leak into the basement area.
I had to change my rear brake pads around 25,000 miles due to a leaking axle seal, but the pads where not worn out, just covered with rear axle fluid, and smoking when warm. .. I did not change the front pads yet.
As for the generator, a new one might be in the $3,000 range, give or take a thousand. If you feel that you will really need it, get a exact quote before making a offer.
My 30E has the optional layout, with the couch behind the drivers seat, and on the passenger side I have a third Captains chair, just like the passenger one, 5 feet behind the passenger seat, and I built a table between them. I just did not like the dinette in my last motorhome, and decided to get this option from the factory.
Good luck on your purchase!
Fred.
Fred.
38,781 PostsLatest Activity: Aug 12, 2026
