CA_Traveler
Dec 26, 2020Explorer III
Don't underestimate the work involved in dlam as it normally involves moisture and bad wood. You will likely have to remove a hugh section of fiberglass and then any bad wood underneath. And when it goes back together you need a way to press the fiberglass until adhesive etc drys. Think supports from a solid wall to the RV. My son and I used a LOT of long 2x4s from the ground to the fiberglass on his RV.
