coolmom42
Dec 26, 2020Explorer II
dougrainer wrote:
1. Mini(Older class c) that have a front overhead window are more prone to front overhead cab leaks
2. Class A's are much easier to drive and manuever. I base this on 41 years as a RV Tech that has driven BOTH thousands of miles.
3. But, Class C's have MORE bed space than most Class A's. Most Class A's are designed for 2 people. Especially in the size range you are looking at
4. YOU NEED TO RENT THE TYPE RV YOU ARE WANTING TO PURCHASE. It will cost a LOT of money to purchase and then find out after a few months that the Floorplan does not suit your needs. Renting for a month or so at a time allows you to determine the Floorplan that will suit your needs. Until you actually live and use, you will not be sure of the floorplan that will suit your needs.
5. I base my comments on the 41 years as a RV Tech and working for the same Dealer that sells both new and used and have seen the hits some customers take when they buy without knowing positively if the Floorplan will work for them. Some are well off and will absorb the 10's of thousands of dollars the hit takes when they trade and get the floorplan they want. New or used, you will take a large hit. Doug
This is very good advice.
