toedtoes
Aug 10, 2015Explorer III
Depending on what you consider "camping" and where you want to do it, yes, the length MAY restrict you. If you plan on staying in RV Parks, then the length should not be a factor. Actual campgrounds can vary - generally, the more remote the campground, the more likely length will be an issue. What I recommend is taking a look at the campgrounds that interest you the most - if 80% or more will fit the 31ft, then you'll be OK. You might have to make some compromises (on the 20% that it didn't fit), but you'll be happy for the most part. If less than 80% will fit that length, than reconsider your ideal size.
What to look for:
Water damage - do you see any water stains? Where are they located? If only one around a vent or a window, then you're probably OK (all RVs will leak at some point as they get older - as long as the prior owners dealt with it quickly and efficiently, there isn't any long term issue). If there are stains on the walls, floor, cabinetry (in and out), etc.; if there are soft spots in the walls, floor, ceiling, etc.; if there are signs of mold, mildew, etc.; then you want to walk away - those are signs of a leak left uncorrected.
Chassis Mechanical - get a thorough check of the engine, transmission, brakes, battery, lights, etc. Just like you would a car.
House mechanical - make sure all appliances work (including water heater), run water through the entire system to make sure there are no problems. Check age of house battery and type (if a car battery, then ask them to replace with a new deep cell battery (6 volts or 12 volts, AGM or wet cell, etc., do your own research and figure what will work best for you).
House layout - make sure the layout works for your family. Spend some time in it acting out meal time, bedtime, morning time, etc. See if there are any bottlenecks that make those things awkward.
Generator/Propane - make sure they are working properly and there are no fuel leaks.
What to look for:
