Jun 30, 2015Explorer
nbking wrote:
Some questions on the potential purchase of a 2008 Roadtrek Popular 19:
What brand of shocks would give me the best ride?
How would I repair a small hole in the spare tire fiberglass cover?
What would cause a refrigerator to fail to operate but start again after a lengthy ride?
Any knowledge you can pass on to me would be appreciated.
Bilstein shocks are the most recommended for Roadtreks and those who have them say the ride is dramatically improved.
A small hole in the fiberglass cover on the Continental Spare is not going to effect anything but appearance. The bracket and the chrome rim around the tire is what is holding it in place. You can put anything over the hole or fill it - as was suggested - with resin - and then cover it. I put adhesive reflectors on mine just to improve its visibility in the dark sticking out from the bumper.
The fridge works on DC, Propane, and AC. If your battery was very low to start it would not work on DC and even with Propane there might not have been enough in the battery to ignite the propane (did you have your battery switch on when starting the fridge?). As you drive the TrippLite 750 inverter/converter/charger charges the coach batteries - about to full charge in two hours - and this is a good indication that your batteries were low to start with if your fridge did not work until after a long ride.
Come see my site - linked below in my sig - all about 190s!
