kriscott
Jul 13, 2013Explorer
Questions on Installing new front sway bar
I received my Hellwig front sway bar and will be installing it later today on my 2007 Tioga on the E450 chassis. I do not expect much difficulty doing the install. My question is after the install do I have to have an alignment done? I wouldnt think so as the swaybar is not directly connected to any steering components but I just wanted to verify. Also, my steering wheel is offset to the right. How do I recenter it? Is it like on other cars where you rotate the knuckle on the drag link? When I look under my MH I see two knuckles and Im not sure which one, if either, I should be rotating??????
