wolfe10
Jan 12, 2015Explorer
From Michelin's RV Tire Guide: https://www.michelinb2b.com/wps/b2bcontent/PDF/RV_Tires_Brochure.pdf
LONG TERM STORAGE OF RV TIRES
Unless the RV owner is a full-time RV-er, the vehicle
probably spends some time in long-term storage. But
what the RV owner probably didn’t know is that rubber
tires age when not being used. So, if the owner must store
the RV, a cool, dry, sealed garage is the best bet. Also, some
storage surfaces can cause tires to age faster. That’s why
Michelin recommends placing a barrier (cardboard,
plastic or plywood) between the tire and the storage
surface.
Here are some other steps the RV owner can take to
help reduce the aging effects from long-term storage:
1) Thoroughly clean tires with soap and water before
placing into storage.
2) Cover tires to block direct sunlight and ultraviolet
rays.
3) Store out of a high ozone area.
Note: When a vehicle is stored, tires should be inflated
to the inflation pressure indicated on the sidewall.
Before removing the vehicle from long-term storage,
thoroughly inspect each tire – this includes sidewalls,
tread area, and pressure. If the tires have lost pressure, be
sure to inflate them to the correct pressure before driving.
surface.
rays.
38,769 PostsLatest Activity: Apr 24, 2002
