Harvey51
Apr 01, 2016Explorer
Quick mod to maintain engine battery from solar supply
I was thinking how strange it was to be hooking up a battery maintainer to the engine battery of the small class C parked in the driveway when I have a surplus of power from a solar panel on the roof. Too much work to run a new wire - yes. But there is already a wire from the engine battery to the house battery through the Ford auxiliary battery relay in the engine fuse box. I took the relay out and replaced it with a wire:
Presto, the voltage on the battery jumped from 12.5 to 13.6.
Other small MH's might be using the Ford auxiliary battery charging system, which is just another relay in the fuse box like the ones below and to the right of the yellow circle around the missing one. It connects the engine charging system to the wire heading back to a trailer electrical connector and, in my case, to the house batteries. There are four connections on the relay and a nice little schematic with labeled connectors. To be sure, I checked the voltages on the two connectors marked as points switched by the relay. One had the voltage of the house with its solar panel working (13.6) and the other the voltage of the engine battery (12.5). I removed the relay, put spade connectors on each end of a short #12 wire and (after filing the spades narrower and tapered) connected those two points with the wire.
I intend to replace the relay when traveling and camping to avoid unnecessary discharge and the dreaded dead engine battery on a rainy weekend. In winter, I will still disconnect both engine and house batteries.
