bluwtr49 wrote:
Getting ready to leave for a week and found the RM1200 didn't have AC. Seems fine on propane though.
I found the 5A fuse on the control board was blown so replace it and I think it's working but no way to be really sure short term. I do have a question on the little device used as part of the recall. Should the red light be on when in normal operation?? An just what does it do?
I ask cause the light is not on and I can't remember if it should be or not.
Thanks for any help.
as others indicate if red lite was on the LPG side would not work.Sounds to me like you have either a bad control board and or the 120V heating elements are toast.
If the cooling unit was bad the LPG system would not work either
