MountainAir05
Sep 29, 2021Explorer II
if you are getting the replacement from the same place you need to change. You need to order some high pressure valve cores and install them. If you have car/light truck ones , yes then they will fail.
I too run over 100 lbs and not have a leak in many years. I do keep a pack of high pressure valve cores on hand just in case. I also put them in my other vehicles.
just look in my book and low pressure cores are good to 60 lbs and high pressure ones are good to 300. The ones I use on Vehicle /home air condition system are at 600. You could be getting them for the lower pressure of 60.
38,767 PostsLatest Activity: Sep 19, 2016
