Pangaea_RonExplorerSep 27, 2021Radial Tire Valve Core FailuresMy front radial tires are Toyo 245/75R 22.5. When checking air pressure (105 pounds), I occasionally have the cores fail which allows air to escape dramatically, and I need to scramble to get the c...Show More
ferndaleflyerExplorer IIISep 29, 2021I run 105 also on the same size tire but I have never had a valve core failure.
Related ContentBias ply vs. radial tiresRam Cummins/Aisin FailuresWater Pump Failure Traveling To The EclipseJack Failure DisasterTire Failure
