Pangaea_RonExplorerSep 27, 2021Radial Tire Valve Core FailuresMy front radial tires are Toyo 245/75R 22.5. When checking air pressure (105 pounds), I occasionally have the cores fail which allows air to escape dramatically, and I need to scramble to get the c...Show More
RLS7201Explorer IISep 29, 2021I suspect your tires have some sort of balancing stuff in them, causing the cores to not fully close.Richard
Related ContentBias ply vs. radial tiresRam Cummins/Aisin FailuresWater Pump Failure Traveling To The EclipseJack Failure DisasterTire Failure
