univmd's avatar
univmd
Radiator vs. CAC vs. Condenser?
I have a rear radiator. What is the difference between the 3? Where are they located in relation to each other? What is inside each of the 3, pink radiator fluid in all 3? I have a Freightliner with ISC Cummins 360, Gulfstream Tourmaster 2008.
I only see what I think is the radiator. I do not see a second layer sandwiched with it? (I do not see a second smaller radiator-looking device on the side like I see on some rear radiator 2005 Monaco Diplomats.)
The reason I ask is because after 10 minutes of shutdown, passenger-side bottom corner of radiator will leak a few drops of pink. Then stop. Does not leak while running. What might be going on? Advice? Thoughts?
With warm regards, James
