- RLS7201Explorer II
sssooo wrote:
This is not after market radio ,I can’t find a fuse panel can anyone tell we’re it is??
there is a black box under the hood that looks like it could be the fuses but I can not get it open it has 4 little tab on it but I cant figure it out??
That black box is your battery control center.
Twist tabs ¼ turn, pull out tab, pull off panel.
There should be 2 fuse panels in your MH.
One is somewhere by the left side of the dash. The other is located beside the circuit breaker panel.
Richard - sssoooExplorerThis is not after market radio ,I can’t find a fuse panel can anyone tell we’re it is??
there is a black box under the hood that looks like it could be the fuses but I can not get it open it has 4 little tab on it but I cant figure it out?? - Larry202brExplorerAlmost all aftermarket radios have a built-in fuse located on the rear.
- RLS7201Explorer IIProperly built MHs do not have unlabeled inline fuses. They have labeled fuses in a fuse panel.
Richard - sssoooExplorerthere is a plug with about 10 wires on it I followed it to the conduit its about 1 foot to the conduit no fuse?
- crawfordExplorerit should be a inline fuse do you see the wiring from radio? can you see the power lines did you follow them down. Has someone else added a newer radio then what was in it before?
- sssoooExplorerI pulled the radio all the way out there is no inline fuse in the wirers ?
- sssoooExplorerI have the radio out that’s how I blew the fuse I didn’t see a fuse there but I will look again
Thanks - crawfordExplorerNo the fuse is wired in the battery feed wire on radio you may need to pull radio to see in line fuse. Remember you have 2 power lines one for radio and other holds memory for channels and clock and settings.
- AvaExplorerOm my rig the radio fuse is with the chassis fuses inside the battery compartment
38,778 PostsLatest Activity: Jun 06, 2026
