- wvabeerExplorerSorry, late to post my result. The radio was shorted blowing fuses. They were in the power cord compartment as you guys said. Thanks for the help.
wvabeer wrote:
dougrainer wrote:
wvabeer wrote:
dougrainer wrote:
The Radio fuse is located in the Shore Cord compartment on the back wall. Doug
Above the bed????? I checked that one it is good. There must another location I am missing.
SHORE CORD COMPARTMENT! This is where your 50 amp power cord to plug in the 120 Shore Power. Above the bed is the 120 breaker BOX:) Your LP/CO detector fuse is also in this compartment. Doug
Ok thanks I will dig into there.
Sorry, I meant the BACK WALL of the shore cord compartment. I can see why you thought the back wall of the bedroom. Doug- wvabeerExplorer
SHORE CORD COMPARTMENT! This is where your 50 amp power cord to plug in the 120 Shore Power. Above the bed is the 120 breaker BOX:) Your LP/CO detector fuse is also in this compartment. Doug- wvabeerExplorerThis is what happened the radio quit so I wired the chassis hot to the switched side so the radio worked. While going down the road it quit. I check both hots and they are open. so I imagine there are two fuses out somewhere. Maybe an inline but I cannot find them.
- pianotunaNomad IIII have an undocumented fuse for the dash radio in line between the cold side of the main battery disconnect switch and the radio.
- robatthelakeExplorerThere are multiple fuse locations on My 98 for whatever reason there are actually 3 that have fuses labelled radio but only one that seems to be correct. not sure why the others even have fuses in the space.
- wvabeerExplorer
Above the bed????? I checked that one it is good. There must another location I am missing. - The Radio fuse is located in the Shore Cord compartment on the back wall. Doug
38,778 PostsLatest Activity: Jun 06, 2026
