-Gramps- wrote:
Get a pool noodle and cut two sections about a fool long (you may want to measure first) They should be long enough to place them in an upright position on top of your slide out at each end under the topper to cause a tent like effect. This will cause the water to roll off and not pool. Remember to remove them before you retract your slide outs!
Also it is a good idea to get a spray can of cloth uv protection/water repellent and seal the topper seams. Water will seep thru them.
Pool Noodles also work good under your slide topper when it's extremely windy!
