Gjac wrote:
Two Jayhawks wrote:
Check out this link. I'm not sure the lowered rail chassis doesn't offer the most basement.  As for knowing how much weight you can stuff in you'll need to know unloaded vehicle weight per axle.
 Thanks for the link. From what I gather the raised rail is only on larger DP's as JRP stated also not in the size that I am interested in.
Correct, mostly. A raised rail chassis is a diesel thing, doesn't have to be a larger one. Newmar make a 34'er with a raised rail chassis, I'm sure other do too.
Gassers are all straight rail.
