Handbasket
Jun 04, 2013Explorer
My best friend is a mechanic & NC licensed inspector. Just in case there's still confusion, pretty much _any_ state-licensed inspection station in NC _can_ do a state-mandated safety inspection. This is required for all motor vehicles licensed in NC. At a minimum it's a lights-tires-brakes-horn-wipers-exhaust-window tint visual & audible inspection. This is necessary before annual license renewal. The problem comes in when it won't fit into the bay, or on a level pad outside (theoretically required for checking headlight aim).
Then on top of this, some counties also require an emissions inspection at the same time. These are mainly the most-populated counties. For my county (Buncombe) it's 1996 and later (OBD II), and under 8200 lbs. They plug in a wireless OBD II reader, and go to the NC state DMV website; the code reader is linked to the state website, so it's hard to fake an emissions test.
I suspect the OP will be exempted from the emissions test on weight. Even my little Tiger class C is. But that's my county. I'm not sure of the OP's county regs. The best way to be sure is to do some reading on the NCDMV website.
Jim, "Mo' coffee!"
Jim, "Mo' coffee!"
