Bill_Mirrielees
Jul 04, 2013Explorer
Annual State Safety inspections are required for all motor vehicles in the State of NC. You cannot renew your registration without a current and up to date Inspection.
It is a 15-25 minute process. It must be done by a State Licensed NC Inspection Station.
Make sure ALL your lights work (including license plate lights), your horn and make sure your tires have good tread and little to no sidewall dry rot. You will be failed, have to have the items repaired and get re-inspected if you do not monitor these items in advance.
It's NOT the Inspection Station's fault if you know about these things and try to slip them by and get failed.
Cost of the Inspection for an RV (non-emissions) is $13.60. Most RVs are over 8500lbs GVWR and are thereby exempt from emissions inspections.
There is NO inspection required for transients or tourists unless you fall in love with our beautiful State and wish to register your vehicle here!
