lordnorth
Aug 24, 2014Explorer
tatest wrote:
The fact that the Admiral is on 22.5 wheels and the Mirada is not, suggests that the Mirada is built on a lighter capacity (lower GVWR) chassis. Empty, it might be nearly overloaded.
Tatest,
You actually have given me a lot of information in your post. I didn't know about interlocked walls - still not sure what I would look for to confirm whether or not they are. But good information none-the-less.
I am pretty sure this particular coach was made by Monaco. Depending on the source (like everything else) some people like Monaco... others don't - for what that is worth.
One thing I found TRUELY interesting is that they both have a GVWR of 22,000lbs. Considering that the HR has a higher UVW... it means that it is closer to being overloaded than the Mirada is.
I am learning more with each post!
38,782 PostsLatest Activity: Sep 10, 2026
