The hold down bolts secure the whole A/C unit to the roof.
Remove the complete ceiling grill. 4 corner bolts......they should just be 'snug' (40-50 INCH LBS----not foot lbs). The roof gasket should only be compressed to one-half of original thickness. Gaskets are roughly 1" thick so don't compress more than 1/2". Over compression can cause roof leaks AND can block evap coil drip pan drain holes....condensation from evap coil can then be pulled over into discharge plenum and leak into inside of rig.
Compressor rattling..then you will need to go on roof and remove shroud and check what is loose inside the A/C unit.
