egh33 wrote:
OK, I had the fans replaced, and that little round thing that tells the fans when to come on. All that, and still no help. 54 degrees in the fridge and minus 4 in the freezer. Haven't got the bill yet for that repair but it took 3 guys to pull it out and put it back.
I do know the fans were $107.00 each. any more suggestions????
why were the fans replaced in the first place??.They dont fail very often from what I have experienced or read about? even if the fans had failed unless it hot out the fridge should cool properly.Mine does and fans only come on in hotter wather
I assume the thermister has been tested ? Does it cool poorly when either on LPG or 120V
Is it venting properly? is the thermostat reacting correctly(circut board)
cooling unit blockage I have read will cause major cooling problems
