Emperor
Jan 06, 2014Explorer
The ballast resister is in the circuit to drop the voltage from the battery voltage of 12 volts to 9 volts. That is why it burns up the points when you jumper the ballast resistor.It can cause the engine to no start if the circuit is open and the points have no voltage.
38,763 PostsLatest Activity: Jul 22, 2018
