Salsapants
Jul 27, 2023Explorer
1995brave wrote:
Is your fresh water tank metal? If it is it probably pressurized with about 30 psi of air. Unless it was converted to a 12 volt water pump. It it's a plastic tank you have a 12 volt pump. Do you have a house battery or converter? Plug it into 120 ac and see if you have a switch somewhere that says pump or water pump.
I HAD a house battery in there but it was old, so I took it out. I plugged the main cable directly into a plug and from there I can have the AC and other things running. There's a switch on the side of the sink that i've flicked off and on a couple times but have never heard it do anything. Would I need to have the water tanks filled before it will do something?
38,707 PostsLatest Activity: Jan 05, 2014
