zigzagrv
Aug 21, 2023Explorer
Did you check your battery voltage? Had a similar situation once where after I would stop for a short while and when restarted, it would run rough and throw codes till I got up to speed. Turned out battery was bad and till the alternator built up voltage, this would happen. New battery solved the problem.
38,769 PostsLatest Activity: Apr 03, 2026
