railsbackg
Jun 19, 2021Explorer
RLS7201 wrote:
Most MHs have poor headlight adjustment from the factory. Start with adjustment. Hot spot should hit the pavement 30-40 feet from the front of the coach. Then add relays to the headlights to make sure they are getting proper voltage. Then if all else fails add LEDs. You will need to readjust your headlights after adding LEDs.
Richard
Thanks for your reply. I have read a little bit where they may not be getting the proper voltage. And not sure how extensive I want to get with it. But If I can get some improvement with a simple upgrade to LED I think it would help me out a lot at night. As it is now I really need to drive with my high beams on. But I will certainly try and check the adjustment. Not sure why they wouldn't be adjusted correctly but you never know I guess.
38,709 PostsLatest Activity: Mar 09, 2025
