GordonThree
Dec 22, 2017Explorer
Re: Accumulator tank pressure
I always run maximum sidewall pressure.
Joking aside, you want the pressure to be under or the same as the pump cut off. You want the pump to build a little pressure in the tank.
Setting the pressure too high means the pump cuts out before filling the tank.
