MSGTRETIREDCSP's avatar
Sep 29, 2013
Accumulator Tank
I'm getting all set to replace a water pump. I'm thinking of installing a accumulator tank also. I've never had one before and I've heard they can help reduce the wear of a pump? I'm replacing a 5.7 Shurflo with a newer 4.5 gpm Shurflo. My question is have any of you ever installed an accumulator tank after just using a pump before? If so, did you see any benefit with an accumulator tank? Do they help or do they reduce the flow of water? Thanks for any advice.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
